Need a l drive tech or someone that knows about them
Joeyforce
Hi I have a 1990 bayliner 2070 l drive with a 120 I'm having a shifting problem I can get the gears to work on the trailer but when I hit the water and cruise I end up losing reverse. I replaced the cable 20 years ago and I could never get it right I think the cable was to Long now from my understanding there's only 2 cables for the l drive a 13 and 14 foot cable I have a 14 please help
foodfisher
Re: Need a l drive tech or someone that knows about them
Your best bet is to spend whatever it takes to get an OEM manual that covers your specific engine and drive, prepare to do it yourself and then hope parts are available.
jerryjerry05
The length, long or short can make a difference.
Too short.Can actually pull it out of gear.
Too long is not so bad.
After 20 years you remember what size came out???
What's on there now?
BlueFishCrisis
What caused you to have to replace the cable when it was only 3 years old? Any other damage perhaps to the shift mechanism? Describe "losing reverse".... It won't go in, won't stay in, just grinds, does nothing??
Joeyforce
We were told to replace them bc we did water skiing I do realize now that's a bunch of bs. What happens is the shifter won't go into reverse . Is there a special way to adjust the shift cable.
jerryjerry05
Try unhooking the cable at the drive.MOTOR OFF!!
Then shift the drive by hand,turning the prop as you do it.
Then move the shifter around.F N R then see if the connectors match.
Adjust as needed.
Or bring it by and I'll help :)
Joeyforce
Don't remember ... A 14 foot is on there now ... Jus seems to me there's alot of slack at the lower unit . I wonder if the marina gave us the wrong cable
Joeyforce
Adjust as needed.
Yeah we did that everything is good. Do u think I need the 13 foot cable instead of the 14 it jus seems a lot of slack under there and the load from the water is pulling it out of adjustment
jerryjerry05
Post a pic of the under side.
The cable shouldn't really stick down in the water.
Joeyforce
Where u located?
jerryjerry05
Fl.
I add that to the posts when the OP doesn't fill in the profile :)
Post a pic.Like i said the cable shouldn't stick down into the water.
Joeyforce
Ok I'll do it this weekend
