Need a little help troubleshooting, 01 Escape won't start
jtexas
Re: Need a little help troubleshooting, 01 Escape won't start
ok, buttoned it back up, still no start.
still haven't got around to buying the fuel pressure tester, but on a hunch, after trying to start it, I disconnected the fuel line at the fuel rail. No fuel there.
Does that pretty much confirm a fuel pump failure? (Pressure regulator is integrated into the pump on this car).
my1stboat1
im a ford master tech. if you havent gotten to the bottom of this pm me.. ill step you through it
jtexas
fuel pump did the trick.
thanks to all who responded.
642mx
Glad you got it fixed. I hope you replaced the fuel filter aswell. ;)
joebob14
if you had a bad fuel pump but the car didnt throw a code I would check the fuse for the obd output. In fords they have a habit of blowing the fuse instead of lighting up the dummy light for some reason.
