Was running about 30mph in 25ft of water and the motor just sped up.
Raised the motor and the prop is about 2 in. out. I can push it back in.
The Prop nut and cotter pin are still in place. Will post more pics this evening.
Is there a shear pin or something that could break and cause this to slide out like this. Replaced the water pump housing several months ago but other than that no lower unit work has been done.
If the propshaft moves with the prop, you have a broken propshaft. Not a difficult fix if you have access to a MONDO heavy duty pair of snap ring pliers. A shop manual is a must, too... Propshafts aren't cheap. I would recommend a reseal in the process, too...
- Scott
Here are the additional Pics
If it is a broken shaft does someone know where I can get a used one.
Just priced the Shaft along ranges from $279 on ebay to $425 through Evinrude.
Tore my unit apart and I have a crack on the inside.
Found a complete lower unit on ebay for a 85 Johnson 110HP.
Will this work on my 84 Evinrude 115hp. They are both 20" shaft. I do not know the model number of the Johnson.
If it was a Evinrude then I know it would work but do not know about a Johnson.
