Fiat4Fun
Thread starter- Joined
- Sep 14, 2009
- 229
So, in one of my previous posts, I mentioned some nasty sound then I stopped the motor.
This on my 260HP 1986 Alpha One Gen One drive.
After pulling the outdrive, I found metal pieces in the upper gear housing, and I can't turn my drive shaft.
The interesting thing is, before I pulled my drive, I started the motor, and saw the drive shaft spinning!
Thought maybe I lost the engine coupler, but found not signs of it on the drive shaft splines.
When I pulled the drive out, I can't spin it at all. I did notice that the water pump from the lower was not
pulling water from the muffs when the motor was running It also did not go into reverse of forward gear.
So, I am convinced I need a new outdrive. I am going to get a complete unit, even though my lower was new from Sierra earlier this year.
I am just afraid that metal shavings and stuff might of messed up the new lower.
A couple of questions, I have a 1.50R ratio drive marked on my original upper, so I assume that is now the 1.47? The other question I have,
is there any advantage of getting a different drive ratio, like a 1.67?
Right now I am thinking of getting a SEI complete unit, any great deals out there and are they readily available?
Thanks and any other suggestions would be greatly appreciated.
Bob
Bob
