Re: need advice 89 glastron carlson ss buying help
glastron are noted for the floors and transom going bad. and engine that has sat 8 years, is very questionable as the outdrive. 2 K for a questionable hull and engine, your buying a trailer. and lots of work. why has it sat for 8 years. the first thing i would do is pull the plugs, squirt oil in cylinders, pull distributer and prime oil pump, as all the oil has long since dripped off. then try to turn it over by hand, wrench on harmonic balancer nut. if could be siezed by rust, exhaust manifolds could be shot. water pump. and on and on. was it winterized, if not run. it really sounds like a tow off to me. and the seller should be happy.
