2550SX
Thread starter- Joined
- Jul 10, 2020
- 40
Hello,
I have a 1992 Chaparral 2550XS with a base 330hp 454 with the peanut port heads. The engine has about 1400 hours on it and I can still get to 51mph on the GPS. According to the specs I can find online my boat weighs 5100lbs dry. I am considering pulling the engine to do some other work in and around the bilge area this winter and I am debating either putting the current engine back in it or take this opportunity to put in a fresh engine.
I was looking at engines online and I see this company in Florida and they offer three engines that I am interested in. I would like to hear your opinions of which you would recommend.
1. Same base peanut port 454 https://marineengines4less.com/new-7-4l-marine-base-engine-replaces-years-1991-present/ This would probably be the easiest swap as I can reuse the intake manifold.
2. H.O. 454 with rectangle port heads https://marineengines4less.com/new-7-4l-ho-marine-base-engine-replaces-years-1991-present/ This engine revs higher than the base version with more HP but I am unsure if my boat would be considered too heavy for rectangle ports. I would probably need to get an aftermarket intake manifold.
3. There is this 502 https://marineengines4less.com/new-...marine-base-engine-replaces-years-2005-newer/ but it says 2005 or newer. I am unsure why this could not be used in my boat. Does 2005 and newer mean it was designed for fuel injection and not the carburetor that I have?
All three engines appear to have fuel pump bosses so I can bypass that stupid oil filled raw water pump which I hate.
Also, while I am asking. Has anyone here had any personal experience with this company or do you have other marine engine companies that you recommend I research?
Thanks in advance for your opinions
