Need advice how to remove broken bolt from engine block
fairshopperguy27
I had the same thing happen to me last year. I took my pick hand tool, stuck it in the hole and started turning it lefty loosy until it caught on where the thread had broke off and it threaded right out!
fishrdan
Thx guys! my question is right now if i need to order special starter bolts or i can use the regular ones(i bought regular ones)?
You need special "starter" bolts, they are knurled to fit tightly in the block. Though, it's been a week and hope you have them by now.
One question, does your starter have the bracket, to support the end of the starter? For some odd reason, 3.0L engines use the bracket where other engines don't, and if you broke a starter bolt, I would make sure the end bracket is installed. If it's missing, you may be able to cobble one up, I made one from a section of aluminum angle.
smokeonthewater
Huh,..??..?? The starter has to use Starter Bolts, they're quite Special, 'n No nut, the threads are in the block,....
No other way to do it,....
First Bondo post I ever saw that didn't start with Ayuh!!!!!!!
Fikus
I dont have the bracket,ordered starter bolts, by any chance may be you have a pic of the bracket :)
Fikus
trying to find the part number for the bracket,by any chance may be somebody have it?
Fikus
You used this once or twice and the bolts unscrewed, are you sure you didn't mess up the threads or something?
As for the brace, here is one for a 1987 305/350, but what motor do you have? P/N 12404 NLA but google it
http://www.mercruiserparts.com/Show...14&bnbr=10&bdesc=STARTER+MOTOR+AND+ALTERNATOR
no,threads are good.i screwed it back, i have 3.0L 2002 i'm using this starter
http://www.ebay.com/itm/OEM-MerCrui...ash=item1c3b681e63:g:-4AAAOxydlFS2EMX&vxp=mtr
http://www.ebay.com/itm/OEM-MerCruis...FS2EMX&vxp=mtr
For them to back out that quick there is something else going on. Suggest using Blue Loctite
In this case a serial number would be best but here is two
P/N 863212 for S/N 1A072812 and up
http://www.mercruiserparts.com/Show...89.png&inbr=13809&bnbr=10&bdesc=Starter+Motor
P/N 807213A1 S/N 0L010042 thru 0L096999
http://www.mercruiserparts.com/Show_...and+Alternator
Both will probably work but have a look
JustJason
When you put those bolts in make sure you actually torque them down with a torque wrench.
Fikus
Fikus
Got all parts,washer also must have,it goes between bracket and block,installed oem starter bolts,when i removed old not oem starter bolts they was bent,and its after one day ride :), now all good!
