Glaspar_Fan
Thread starter- Joined
- Jul 21, 2012
- 63
I have a 27 foot Searay with a poorly placed bait tank supply thru hull fitting. The previous owner must have placed it where he did because it was easy to get to without any thought to it being in the way or what would be on the other side. I can accommodate the inconvenience of having the plumbing sticking up in the engine compartment right where you need to stand to service the batteries, etc. But on the outside, the thru hull strainer/inlet sets square on a trailer bunk. The one time I had the boat out, there was a bad list to port while on a plane with the tabs up. Walking side to side didn't have much effect. No sign of listing at rest, so the boat seems balanced OK. The more I think about it, the more I think the area around that thru hull is going concave due to the pressure of the trailer bunk and taking a set that way.
So any way, I'd like to remove the thru hull and fill the hole. Any suggestions? I've been thinking of making a mahogany plug and epoxying it in. Then fairing with some glass outside and reinforcing inside with a board and more glass. So what's the right way to do this? I've worked with West System epoxy before (made my own car fenders and nose) but never tried patching a hull.
Thanks,
John
Thanks,
John
