On my boat the 21p basic aluminum will not hold when cornering or even going straight in rough water, or at trim much over 1/4 on the gauge. I know now it is the wrong prop after some research on this size and brand of boat (the one in my sig). I can even get it to blow out on a holeshot if I have the trim up even a little, not even to the 1/4 mark. When I am cruising at about 3k rpm trimmed up and nail it all the way the prop spools up and then the boat speed catches up in a couple of seconds. Slip calcs are not good.
It had a High Five 19p on it when I bought it, all vent plugs were in. First time I took it out I got it to overrev, kinda freaked me out. It accelerated well. I was just going to try to get used to the potential overrev, but didn't like that and figured I needed a prop change. It also felt odd in reverse as well, had to give it a lot of throttle before it would move. Just not used to that feeling. So I sold it and got the 21p alum. Even though the engine is just under max RPM's at WOT, this was a BAD decision.
Now I want to fix all this with a new prop. Short list is...:
No budget for expensive prop-swapping supertune effort this year, so maybe the known entity, a High Five 19p is best "economcal" choice. Not sure if going to a 21p on the 5blade may be too much. I like the Enertia because it seems to be an aggressive prop with the rake needed and is available in the one inch pitch increments. I do not know how it compares to a High Five. BTW: Do all of these feel weird in Reverse? or is that just me!
Any experience with this situation? Thanks in advance.
Engine..........: 4.3MPI
RPM range...: 4400-4800
Current prop is Michigan Wheel 21p Aluminum Vortex
Current WOT RPM...: 4700
Current top MPH is about 45
I also have a 19p Merc aluminum and it can overrev. Hits about 45 also.
Original baseline recommendation from Bryant for this boat in 2002 via brochure and owner's manual was a stainless Vengeance. Next up was a High Five. No pitch was mentioned. Further research shows the boat responds best to props with more rake for the bow lift, again this is from reading about props and also testimonials from Bryant owners. Fuel tank is in the front, and the hull has the extended planing surface in the rear. Outdrive seems to be a little higher than some/most. From the evidence, a stern lift prop is exactly the opposite of what the boat's configuration dictates.
- Enertia 20p
- High Five 19p
- High Five 21p
