Need advice on purchase, not a lot of info
eavega
Hi All.
I've finally convinced my wife that we need to upgrade to a bigger boat in order to get a little more enjoyment out of our time on the lake. To that end, I have been trolling Craigslist for a 19' or under v-hull bowrider to replace my currently running 15' tri-hull. I'm really in no hurry since I currently have a boat, but I came across a 19' Galaxy bowrider that looked to be in good conditions from the pictures on CL. Seller's story is that it hasn't been run in 3 years, but motor was working when it was put up 3 yrs ago. The seller is asking a ridiculously low price for the boat (for reference, the asking price is $500), leading me to believe that either something is very wrong with it, or he just wants to be done with it. I'm going to go look at it on Saturday. He is about 90 minutes from where I live. I am not going to have an opportunity to water-test the boat, or even to start it up. I have insisted that I will at least do compression and spark tests, and check the outdrive oil.
The seller is not terribly forthcoming with information. I have asked him the year and make of the motor, year of the hull, last maintenance, etc, and all I have gotten from him is "The boat is in great shape, just had the floor redone, Transom is solid, seats are in great shape, motor was running when the boat was put up three years ago". Nothing about the motor size, issues, last services, outdrive, etc. I can't even see the pictures and the CL ad anymore. The owner tells me that he had to remove the ad from CL because of the large number of responses. Since I was the first response, he will give me the first opportunity to purchase it on Saturday. Again, still sounds fishy. If it were not for the low pricing of this rig, I wouldn't even be pursuing this any further. I am realistic and I know that this just seems way too good to be believed, but given the asking price, its worth at least a look.
So, the catch is that I know absolutely nothing about I/O boats. I've had three boats so far, but they have all been outboards (and relatively small ones at that). I need to know what to look for that would point to big problems, both from a motor/outdrive perspective, and from a hull perspective with regards to failing transoms. If it were an outboard, I would know to check compression, spark, LU, steering, shifting. I'd know to look to see if fiberglass is cracked in the corners or near the transom bolts. I'd know to tilt the motor up and see if there is any movement when you put weight on it. Is there anything additional/different that you would look at when considering the purchase of a used I/O boat? Any additional information would be great, since it seems that I am going to have a very small opportunity to inspect the boat prior to purchase. Thanks in advance
Rgds
JASinIL2006
Re: Need advice on purchase, not a lot of info
Sure does sound fishy, doesn't it? Especially in the middle of the season? $500? Just had the floor redone? No water-test or even running it on muffs? Boat has sat for 3 years without running?
We bought our first boat early this year and those sorts of things became signals to me that something hinky was up with the boat.
If it were me, there would be too many red flags to bother driving to see it. There is a reason he's only asking $500, I would bet.
TilliamWe
Banned
At that price, you're getting a trailer. And it better be a good one.
It's probably an OMC stringer drive, which is why he won't tell you. Or, just as bad, a Mercruiser 470. The Galaxy we bought new in 1977 had an OMC, so I know they used them.
eavega
So, OMC drives are to be avoided? I should be collecting as much information about I/Os as possible so I don't have to ask these questions again for any other boats I may consider buying.
I am not holding out much hope that its a worthwhile boat, but my boater's curiosity dictates that I MUST go see. One more piece of information I got is that I need to bring two 5-lug trailer wheels with me. So much for the "good trailer" theory. More red flags...
-Rgds
southkogs
OMC went out of business years ago - and in the '77 range the outdrive would be a OMC Stringer Electric Shift. Not a bad system, but parts are getting hard to get hold of, and it's tough to find mechanics to work on 'em. Ask me how I know :rolleyes:
Something else to consider - even after the "project" of putting this boat together, she's gonna' require a considerable amount of attention to keep running (being 40 years old). Consider that compared to getting something newer/lake ready that won't require quite as much maintenance.
eavega
Yeah, definitely don't want to be in the business of having to work on the boat every other time you take it out, plus the constant worry of the thing leaving you stranded on the lake. Previous to the 70 HP Johnson I have on my boat now, I had a 1972 50 HP hydroelectric shift motor, so I understand about hard to get parts and no mechanics to work on it.
While I am not afraid of 40 year old boats (my current boat is 36 years old, and I have it running pretty well), I am definitely not looking to get into another project. I don't mind some minor work but I am not looking for a gut-and-rebuild or even a major tear-down of an engine. I have to say that I have considerably more budget for a boat, and have found in this area reasonable boats can be had for under $5K. I am also not in any hurry since I have my boat that still gets me on the lake and can take the kids tubing. I was going to put the search off until the winter, but I might as well start seeing what is out there. This one just came up and I could not believe the price based on the photos on the CL ad. I may blow the whole thing off unless the seller gets me more concrete information.
