Need advice on rebuilt engines usengines.com...
grezzmky
Ive searched on here and havent found anything. I am about to order a 350 hrs/ 400 ft lbs 383 from them. Its $3200 shipped with no core and a warrenty. Any advice? any expiriance? Its replacing a 350 in a 23' VIP. The boat has the King Cobra outdrive.
grezzmky
Re: Need advice on rebuilt engines usengines.com...
not to be a jerk, but 55 views and no replies? Nobody has bought a rebuilt engine? I atleast Id get some grief about the OMC... haha
Ayuh,... Many of the guys here have bought motors from Rapido, with good results...
Haven't heard much about USengines....
Personally, I can't imagine dumpin' 4 Grand into a hull with an OMC King Cobra drive myself...
zbnutcase
I'm with Bond-o on that one!
grezzmky
The boat was free. It was in covered storage all its life and is very close to being brand new. rapidos website doesnt work.
krisnowicki
http://www.rapidomarine.com/
works for me... get it from him. He has lots of street credit. I just did a repower two years ago from OMC to merc. I sold all the omc stuff and got a good chunk of change back. I would do the swap to MERC before something breaks because it will
StevNimrod
Heard a lot of good things about Rapido. Not sure if they still do, but at one point they offered a "no questions asked" warranty. I don't think they offer a 383 though.
I called US Engines when I went from 350 to 383 and it seemed like I caught whoever I talked to having a bad day. Gratuitous use of what I call "marine engine mystique". But like I said, might have been a bad day. But do check their warranty. Warranties have a way of having prohibitive terms and conditions. Especially since many engine failures aren't actually a problem with the engine itself - somebody failed to winterize properly, didn't keep an eye on the exhaust system, overheated, etc. and most warranties don't cover failures from abuse or neglect. Which are two very broad and subjective terms.
After I looked at a bunch of different places online I ended up finding a local shop and don't regret it. I found that local shops I talked to gave better service, more feedback (as to what I was trying to do and the best way to do it), and turned me on to good parts at very competitive prices. You might be surprised how much motor they can build for $3200 if you get everything through a local guy.
No matter which way you go, also be sure to ask what they're using parts wise. Are cranks new or turned down, and if so how much? What is the maximum overbore they use? What internal parts are cast or forged? Is the rotating assembly balanced? You can get something that runs without every aspect being ideal (since you don't need a drag racing engine), but if you get a gearhead buyer at some future point being able to converse about the specifics might be helpful.
But check into the warranty. 7 years is hard to beat if all (or a substantial part of it) is "no questions asked". Otherwise, if you can find a quality shop locally you know you can always go in and talk directly to the owner if you ever have a problem.
grezzmky
I recived my rebuilt engine today from Rapido. Seemed like a good guy to deal with. I do however have a couple of concerns however. One He said if I ordered it the day I call he would upgrade me to flat top pistons bumping me from 300hp to 325hp. However, The crate and paperwork says 300hp all over it. Im fine with the 300hp cause Im sure the flat top piston motor will require premium fuel cause of the bump in compression. My real concern lies in the gaskets. It looks like he used regular truck head gaskets... Is that gonna be ok? How aboout the intake gaskets he gave me. It is a compplete felpro truck gasket set. Also what do I use for exhaust manifold gaskets? And can I use an after market alum intake? will it be bennificial? THANKS
Raystownboater
When my engine came from Rapido, he sent along a box with ALL the gaskets including the exhaust gaskets. I am by no means an expert but from what Ive researched and learned, the block Rapido uses is more than likely a truck block and I believe the gaskets he is using are sufficient. If you dont have exhaust gaskets in the set, or you have questions about the engine, I would give him a call. They are more than reasonable and seem to bend over backwards to make sure their customers are satisfied
