My other boats had porta potty
Recent purchase of a cruiser that has masserator with holding tank
Pumping out is new too me and not sure what too look for . This is also a job not eager too tackle
While at fuel dock I use waste pump out when it reads full.
Gauge in bathroom showing level of waste in tank
When I empty gauge never goes below 1/2 on each pump out ????
Spending long periods of time with pump hose, attempting too empty waste holding tank bringing level below 1/2 . Priming often and no change, never goes below 1/2
Meter could be reading in correct but same meter has duel function , reads clean water level in clean water holding tank and seems accurate. When switched other direction it reads waste tank level which clearly works but after long period of time pumping out never drops below 1/2
If there was a blockage nothing would come out ?? Why does it not drop below 1/2 ?
Boat kept in a high & dry yard . When I want it put into water I call . Yard is open outside yard that I can work on boat.
I can get too sea **** and empty holding tank into buckets, and then dump into toilet , .
If I was too do this do I turn pump out key on in bathroom ??
Not familiar with how the entire toilet set up works from when I put masserator on , were the clean water comes from, cycle
Advice is appreciated
thanks
thanks
