need advice please- engine shot?
tnvolsdj
I am not very mechanical so please be kind. Boat was running fine then died. Was able to restart, but could barely go over idle without enging quitting- "limped" back to dock like that. Ran compression test both cold and warm. I read 2 different instructions and got the following results:<br /> cold warm<br />top 129 123<br />middle 139 129 <br />bottom 129 123<br /><br />I took off the head and everything was dirty, but I couldnt really see any damage or anything. I am not sure, but wouldnt damage be obvious?<br /><br />Also I noticed a little fluid (gas mix) collected in the bottom of the carb intake.<br /><br />85 Force 85 HP<br /><br />so is the engine ( and me) screwed? mechanic said if compression was bad I was looking at 2K and he didnt even want to work on a POS Force. I have the manuals, but I am not sure I could do it myself. Also, if buying a replacement engine, does this one have 20 inch shaft??
JB
Re: need advice please- engine shot?
Hi, Davod.<br /><br />Welcome to iboats. :) <br /><br />No, your engine is not terminal. The compression numbers are fine.<br /><br />From your description it sounds like you have lost fuel flow or lost spark to one or more cylinders.<br /><br />Bad idea to pull the head. You will need a new head gasket.<br /><br />Put her back together and try squirting some fuel premix into the carbs while running. Does it pick up speed? That would suggest a gummed up carb.<br /><br />Does it have spark to each cylinder? You may have lost spark on one or more.<br /><br />Is the throttle plate opening fully on all carbs?<br /><br />Let us know what you find.<br /><br />Good luck. :)
roscoe
Ditto JB.<br />Your compression readings look great for a motor of that age.
tnvolsdj
Some good new- thank you! Is it possible that I am not doing compression test correctly, because I took it to mechanic and he said once cyl was bad? I did it myself because I want to make this a whole learning experience and sometimes Im not all that trusting. Surely, the mechanic would not be trying to rip me off? <br /><br />As for the spark - before I took off head, I had one of those little tools that lights up if spark is going. I got a shock using it just placing it on the wire for the middle cyl. It seemed like the plug wires came off pretty easily. Upon inspecting the plugs I found the caps to them were loose. These plugs were installed last year.<br /><br />Since I have the head off, should I clean all the parts ( the insides of the cyldrs too)? What to use? What not to do?<br /><br />You guys are really great to help with the info
tnvolsdj
I got the head gasket and put the head back on. Took it out today and it worked great for a little while, then stalled. Cranked right back up but wouldnt go very fast without dying. I thought -thank God I stayed fairly close to dock! I was completely disgusted. <br /><br />I pulled the boat out of the water and was preparing for the drive home, when I took off the engine cover. A spark plug wire had fallen completely off the spark plug on the top cyl. I took the boat home and compared the old plugs with these newer ones that had been installed last year. The new ones were Napa Autolite the old were Champions. I stuck the old plug in the wire and it appears to have a thicker body and the plug stays in.<br /><br />Looks like I may have found my problem!!!!
CoachHolland
I think your mechanic told you a bad cylinder and two grand just because he didn't want to work on the engine.<br /><br />Glad to hear that it was a cheap fix. I wasn't aware that Autolite made gapless plugs for this motor. The champions are gapless, right?
tnvolsdj
The autolites were not gapless. There old champions were not gapless either L77JC4. Is gapless better?
eurolarva
Merc calls out a UL18V plug for your motor. This plug is not gapless.
