Need advise ASAP
RCR Al
I did my spring maintenance on my boat and now the temps are dropping tonight to 23F for the overnight low.... do I need to panic and re winterize it this afternoon..... or will it be OK for the night
I have a Volvo 3.0L penta in it
Thanks in advance
Al
pevaguy
Re: Need advise ASAP
The only winterizing need is to drain any water out of the engine block, manifold, and riser. Lower the out-drive to the down position so any water in it can drain out.
Texasmark
Does that mean that you hooked your engine up to muffs and ran it and therefore you have water in your block? If so, drain it or put a couple of 100 w light bulbs adjacent to it, one per side and cover it back up. Probably wouldn't need the bulbs since I assume you will be down and back up above freezing tomorrow but just in case.
Mark
RCR Al
The drain taps are a pain in the *** to get to so I guess I have to run it on muffs and re install the antifreeze..... crap didnt want to do that
RCR Al
I have a halogen shop light would that do the trick
RCR Al
And temps are not forecasted to go below 32 again this season..... last year we already had 3 weekends on the water and this year is the pits...
ziggy
any not coast guard approve ign source is a fire hazard. ie halogen shop lights and light bulbs.
drain the water out of the cooling system and you'll be safe from freeze damage.
RCR Al
It didnt take long to hook up muffs and warm up and the put a couple of gals of antifreeze into her.... all done and safe....thanks guys
