outlawfox13
Thread starter- Joined
- May 11, 2009
- 96
Ok, well the wife and I are looking to upgrade our lil crabbing boat(12' runabout with open floor plan and tiller steer) to a Cuddy Cabin. I have found a nice looking 1989 Citation Caprice 195 CC with a 2007 Mercruiser 3.0l. He is saying the floor and interior need replaced/cleaned, so I know I will have to pull the floor and replace it, but he is only asking $700 for it, and that is not too shabby. He said that the boat idles at 2000 rpms because the carbs need cleaned. Is this right ?? Or does the module on the TKS carbs need replaced? Well here is some info on it:
1989 citation caprice, needs new floor and interior work, the two captains chairs and jump seats are in great condition, the side panels, aft deck lid, and engine box were built with epoxy and edges were fiberglassed with epoxy, the engine box has a small spot that is rotting, other then that the interior panels need sanding and painting or covered, i replaced the engine with a complete 135 hp mercruiser, 4 cylinder 3.0l in 2007, ( not rebuilt ) the transom assembly is 1989 and the drive is 1989, the boat comes with a 1983 highlander galvanized trailer, i have put a lot of time and money into boat and trailer, i'm looking for best offer or willing to trade for a wood chipper or a nice newer laptop, the engine alone was $3000.00, i just want tho get rid of boat cause i have purchased another boat. this boat is a one owner boat that i purchsaed in 1991 as a leftover.
1989 citation caprice 195 cuddy cabin.
new seats in 2003
new stereo-2003
side panels, aft deck lid, engine box built-2002
2007 engine in-2007
outdrive 1989
new impeller-2009
new upper bearing and housing cap-2009
new seals and pressure tested-2009
new drive bellow, exhaust, shift bellow-20011
new gimble bearing and grease-2011
new shift cable from shifter to engine-2009
new u-joints-2011
new upper drive seal-2011
new newer stye shift shaft seal and bushing-2011
new plugs, distributer cap and rotor-2010
new porta pottie 2004 ( never been used )
trailer,
1983 highlander galvaized bunk single axel
new tires and galvanized rims with very low miles-2003
new new bearings, races, grease, bearing buddy's and caps, and one new tail light, and new rollers-2010
this boat and trailer needs work and will be sold in as is condition
i was stiil using the boat until i purchased i another boat, the boat is in the water and can go on a seatrial if interested?
repeat, boat and trailer sold as is, needs work.
cash talks.
i have clear titles for both boat and trailer
Is it worth the price and aside from checking for rot is there anything else I should look for?
Thanks in advance Mike
new seats in 2003
new stereo-2003
2007 engine in-2007
outdrive 1989
new impeller-2009
new u-joints-2011
trailer,
cash talks.
