need advise on installing t bar for driftmasters
boatman1971
i installed a t bar to put my new duo pros on but,the tbar has alot of flex in it i guess its because my deck is alum. any ideas????
blackhawk180
Re: need advise on installing t bar for driftmasters
Can you post a pic, boatman? There's lots of ways to add strength to aluminum decks but I need to see your install.
thanks!
boatman1971
thanks!
heres A pic
boatman1971
posted pics need ideas
blackhawk180
The flange is not large enough to spread out the load. You can reinforce either the top (easy) or bottom of the deck. If you had access to some diamond plate, I'd add either a square or circle about 6-8" to the top of the deck then re-mount your t-bar.
boatman1971
thank im gonna add some 1/8 alum. to see if that works
