Need an advice on a prop for 1996 Bayliner 2355 Cierra
Acuario
I have a 21 pitch stainless steel 21 pitch prop to put on but the boat has 15.25 X 15P EOM? can i use this 21 Pitch pro and will be the differences?
eavega
First question you have to ask yourself is, how does the boat run now with the 15P Prop? Does the motor run within its specified WOT RPM range when correctly trimmed and lightly loaded with the 15P? You don't mention the motor, so we can't tell you what the recommended RPM range is for your rig. In broad strokes, if you step up to a 21P prop, you will drop your RPMs significantly; like on the order of about 1000 RPMs. If you are within your recommended RPMs with the 15P, then the 21P will not do a thing for you except to lug your motor and cause it to die an early death. You would also have a harder time getting your boat up on plane.
Acuario
Eng 5.7 v8 mercruiser also the prop i want to use is 14X21P
Maclin
What is the top RPM your engine can attain at wide open throttle with normal load now?
steelespike
If it is operating within its rated rpm range with the 15 the 21 will be sluggish out of the hole probable;y won't reach rpm range.
If you have the prop give it a try.
jestor68
Depending on which 5.7L motor you have, the rpm range is 4200-4600 or 4400-4800 for the 250 EFI version.
The "standard" prop would be in the 17-18 pitch range with the motor developing full(like new) power, according to the Mercury prop selector.
A full throttle test run is necessary to evaluate the current(15 pitch) prop.
A 21 pitch is most certainly too much for your 18 year old motor.
Acuario
TY for all the replies..will take them in consideration
