Need carb help with a 1957 18hp Evinrude
dfrants
got a 1957 18hp Evinrude model FDL-11. She starts and runs but koncks out at idle. what is the recommended setting for the low speed needle?
dfrants
thanks, that and a new fuel line to the carb and she runs great. only wish I could tighten the tension on the throttle a little to hold it at speed desired
oldboat1
throttle or air/fuel mix? If the latter, tighten the needle jam nut(s) after setting to keep them from rattling loose.
