FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Many folks are keen on carburetor kits.-----But why ?-----Not much goes wrong in there.-----What is your motor doing / not doing ?-----If you have issues with running or idling , then start with a compression test.----Post your numbers.
Underload it runs out of fuel. I’m going to try a separate tank. A 115 Johnson crossflow 1997. I have changed everything. I had someone rebuild the carbs but who knows unless you do it yourself. It idles and runs at low speed great. Coil paks good. Stator changed. Fuel pump. Hoses. Squeeze bulb etc. no water in filter
So it keeps running if you operate the manual fuel pump ?------Post your compression test values as well.-----For future reference.----Fuel pump runs with crankcase PRESSURE and there may be issues there.----Part # of the fuel pump you are using now ?
