Water logged
- Joined
- Nov 15, 2008
- 377
I am replacing fluorescent lights in garage with LEDs. There are 4 lights on one switch and wiring includes 1 white, 1black and a solid copper ground. The ground was attached to the metal housing on fluorescents. The LEDs screw into standard light sockets and the is no attachment points for the copper on the sockets that came with the new lights. Can I just connect the incoming and outgoing coppers together so that ground goes through its circuit and just use the black and white connections on the light socket? As you can see my electrical knowledge is not great and I would not be offended if you told me to hire an electrician.
Glenn
Glenn
