Why do you only remove the the top bolts (don't the bottom ones need to be re-located as well?)?Originally posted by XcellR8:<br />Originally posted by Stillfishing:<br /> No crane needed! No boat shop needed!<br /><br />Chock your trailer wheels. Put a trolley jack under your skeg, with a block of wood in between. Loosen the bolts (remove top bolts) and gently jack motor till holes line up. <br /><br />If the hydraulic trim tends to swing the motor out while you're jacking, then tie a line around the leg, feed it under the boat, tighten it and secure it to the trailer winch leg.<br /><br />It's a fairly common method of adjusting motor height on a transom. When you've done it once, you'll see how easy it is.
The bottom holes are usually slotted, so you just need to loosen them. <br />I used the car jack the last time I raised a motor, the jack had a convenient slot at the top, which fit the fin on the motor perfectly.Originally posted by XcellR8:<br />Why do you only remove the the top bolts (don't the bottom ones need to be re-located as well?)?
I just looked at mine and on the motor plate there are five mounting holes for the top and five for the bottom. I also noticed that if I was to raise it up a hole then the metal edge of the transom may get in the way as it is not flush with the transom. Is this normal or will it create a problem?<br /><br />Do you need a website to be able to post a picture (I tried clicking on the image buttom but it prompted me for a URL)?Originally posted by ivar:<br />The bottom holes are usually slotted, so you just need to loosen them. <br />I used the car jack the last time I raised a motor, the jack had a convenient slot at the top, which fit the fin on the motor perfectly.Originally posted by XcellR8:<br />Why do you only remove the the top bolts (don't the bottom ones need to be re-located as well?)?
I'm trying to picture this setup in my mind. A lot of transoms with a rolled top edge have it cut away where the motor mounts, so that the motor can be raised if needed. Guess yours isn't?XcellR8: I also noticed that if I was to raise it up a hole then the metal edge of the transom may get in the way as it is not flush with the transom.
No, how do I post a picture?Originally posted by Stillfishing:<br />I'm trying to picture this setup in my mind. A lot of transoms with a rolled top edge have it cut away where the motor mounts, so that the motor can be raised if needed. Guess yours isn't?XcellR8: I also noticed that if I was to raise it up a hole then the metal edge of the transom may get in the way as it is not flush with the transom.
Thanks, as soon as I get a chance I'll take some pics and post them under a new thread (when I first posted I wasn't sure if I should start a new thread or ask under this one since it appeared mean15 and myself had the same questions).Originally posted by roscoe:<br /> A photo has to be hosted on a website somewhere, then you post the url link here.<br /><br />There are many free image hosting sites.<br />photobucket.com<br />imagestation.com<br />myfishingpictures.com<br /><br />and many more.
Absolutely, positively, 100% true!<br /><br />On rigs that are not set up properly.Raker props have been notorious for a slower hole shot trade-off to get more top end. My bass buddies have always preached that to me, but I have never run a Raker prop. Is that true? BWJ<br />
I don't run a pad type hull, but I have 2 Rakers and neither have given bad hole-shot. I "have" found they work best at the surface.Raker props have been notorious for a slower hole shot trade-off to get more top end. My bass buddies have always preached that to me, but I have never run a Raker prop. Is that true? BWJ<br />
Right on. I understand fully the benefits of Smart Tabs and have put that on my list of upgrades to my rig. Coincidentally, thanks for the input about trim tabs(Smart tabs), seems like 99% of the people that I try to explain these to don't realize what they will do for their boat. Therefore won't even consider them for all the benefits they provide, even though their rigs exhibit all the syptoms(problems) that smart tabs potentially correct. BWJOriginally posted by nautiJohn:<br /> Big White;<br /><br />No matter how good your set up is it will improve noticably with trim tabs / Smart Tabs. The hole shot is only 10% of the benefits. The list is long and hard to believe unless you try them.
