victoryinerie
Thread starter- Joined
- Jun 13, 2010
- 62
Don't know where to start but I have a mess and I need to back up and re-think what is going on:
Here is what occured:
-Engine was missing a little
-Changed Spark Plugs-Found one that was cracked
-Changed Distributor Cap
-Changed Rotor, old was hard to remove had to crack it to get it off
-Tigtened Altnerator Belt
-Changed Water Separator
Yesterdays results:
-Engine turned over no spark
Today's results:
-Had coil tested, ok
-12volts not at coil with key on?
-Hard to get the engine to turn over when it does it is really slow and sounds bad
-Charged Batteries they appear to be at 95% but appear to be draining quickly (not sure how long it takes to run it down with nothing on?)
Any help will be greatly appreciated, not sure to start at the electrical or the starter/engine turning over. Again the engine really ran well before I changed the plugs/rotor/distributor cap, etc....
Greg
Yesterdays results:
Today's results:
Greg
