Need Help 83/200 transducer
DTL504
I recently purchase a Lowrance HDS-7 Insight USA w/ 50/200khz transducer but I will also like to purchase an Transom-mount, with built-in temperature sensor 83/200 khz tranducer for a dual setup.
However I cannot find the part number listed in the manual or website that list the Transom-mount 83/200 khz transducer. I have found the LOWRANCE SB-9BL SWITCHES 2 TRANSDUCERS TO 1 SONAR UNIT, but no luck with the 83/200 khz ducer.
Do anyone know the part # for Lowrance Transom-mount 83/200 khztransducer or can provide a link to this transducer?
Thanks in advance
dingbat
Re: Need Help 83/200 transducer
That's because it doesn't exist. The 83/200 kHZ is standard, single element, 200kHZ transducer.
When you select the unit to run @ 83kHZ all it does is run the standard 200kHZ transducuer at 83kHZ.
DTL504
Thanks for the help. I just order the standard 200khz transducer Lowrance part# 106-72.
