NHGuy
- Joined
- May 21, 2009
- 3,631
Re: Need help aligning engine to sterndrive
If you have the rear mounts in correctly then you need to PIVOT the gimbal bearing enough to allow the tip of the alignment bar to enter the coupler. Does that clarify it at all? Once you have the bar end started you need to figure out which way to raise or lower the front mounts to allow the bar to slide in smoothly.
If you can't get the front mounts low enough get a farmers wrench, they are very thin. Or get a cheap combination wrench, cut it short and then grind it thin so the front mounts can come down as low as necessary.
