pinto 21629
- Joined
- Aug 18, 2003
- 99
i have a 1960 super seahorse 40hp johnson. last sunday i went out for a little fishing on my boat every time i tried to go over 10 on the speed meter the motor would die down then cut out on me but i could start it right back up but at (WOT) it died but if i pulled it back and moved a little it would pick up again at about 10 nots it ran along fine any higher i would have re start it again . when it was running at idle it ran good.a good bit of smoke was comming from the muffler area kinda of like a cloud at low speed i mix the gas right 24:1. when on the trailer putting the tie downs on a green milky looking stuff was dripping from the opening right above the prop but not around the prop and a little from the side that has a screen the water pickup i think. well i think i flooded it when i first put it in the water at the dock i dont know if that would explain the green stuff because i used the trolling motor to go out a little first time haveing the boat in the water when i went to come in thats when i tried to start it again after flooding it about two hours later after fishing. i im new at the boating thing so i dont know much about out boards so if some one can help i would be very very greatful
