need help boat dies when un water
siego99344
hello its ne again the new guy. hahaha frustrated. my boat turns on fine when out of the water but wheb I try to turn it on in the water it struggles really bad until battery dies.. and its a new battery. I dont no what else it can be. sounds great out of water but in water it wont turn over it very often turns over and thats it has a new battery.. anyone help please
siego99344
put it in better terms when I have m uffs on cranks up right away no problems when in the lake it struggles bad to turn on I even hear some clicking going on and its like I have a dead battery but its new its a 351 v8 omc. I am lost to what to look for.
southkogs
I'm not sure what is happening: If you start the engine while the boat is in the water, does the starter actually turn the engine over? I think you're saying that it's not actually starting, but I'm not sure. Or will it just not idle in the water like it will on muffs?
Once it's runnin' the battery doesn't really matter much. What RPM are you idling at on muffs?
siego99344
its hard to explain the engine will turn over in the water with a new battery but once I turn it off in the water it wont turn back on when I go to turn ignition it wants to but sound like something is holding it from starting its sluggish. then after a while all you hear is click click click and thats with a new battery and the rpm is currently not functioning theres a short feom the coil to the rpm somewhere thay I got to look for .
siego99344
from the get go it struggles to turn on but after a while it turns on but just I took out it driving back and fourth for 15 min parked it for like 10 min in the water and it wouldn't turn back on it would click and sounds like a dead battery but I unplugged battery and doesnt sound like its cracking fast enough dont no what to look for
southkogs
Have you had your alternator or your voltage regulator checked?
siego99344
no I have not but even if it'd a new battery straihht from store it dpes that
siego99344
no I have not but even if it'd a new battery straihht from store it dpes that. where is the voltage regulator located at?
southkogs
Not sure on yours. Mine is right on top at the front of the engine.
So, even with a fully charged battery it'll run fine indefinitely on muffs but a few minutes in the water and it's all over? (sorry, I'm not quite getting it yet)
siego99344
yea it's understandable. with new battery fully chatger it will eventually turn on. like yesterday took it out after trying to turn it on it never did. took battery out of my jeep and it eventually turned on. after riding fir 15 to 20;min parked it for 10 min and it never turned back on..it was tryin for a little bit but never turned on. I thought battery was dead bc that's the way it sounded clicking noises and not even trying to turn over. took battery out put back in the jeep and the jeep fired right up like nothing. when I tried turning it on I had to manually put gas in carb and open the throotle and it just clicked and turned over very slowly. but when I fid eventually turn on it ran perfect. its just when I try to turn it on when in the water it struggles badly trying to turn to a point where a fully charged battery ends up going bad from so much cracking. hopefully u kinda get where am getting at... muffs turns on without a struggle in the lake it sometimes dont turn on..
siego99344
its like I turn it off after running for a little bit shut it off and it dont want to turn over after that in a lake but if I have it on muffs can have it one fir 30 min shut it off and leave it off thrn it will turn on like nothing on the muffs but on the lake its a different story... something changes from muffs to lake that dont let it turn on. what idk yet.
midcarolina
I'm having a little trouble following you but.......... If the starter is spinning the motor when on the lake but not starting....Do a compression check the additional back pressure of the water is the difference.
If the starter will not spin the motor when on the lake pull the plugs and look for signs of hydro lock ( water in cylinders )
siego99344
well it does spin the motor out on the lake every now and then not constantly. how do I do a compression check? what are signs of hydro lock? and how do I fox that??
coolbri70
take the spark plugs out and try to start it, if you have hydro lock water will squirt out the spark plug holes, to check compression, screw the compression gauge into the spark plug holes and try to start a few revolutions then read the gauge
