HotTommy
Thread starter- Joined
- Mar 15, 2013
- 1,025
I need advice to diagnose a cooling problem on a 1993 Force 150 outboard. Here are the relevant facts.
- Engine ran well with no obvious problems for several months last summer. It is used mostly in deep lake water.
- While running at about 4500 RPM, the engine started losing power and I slowed to idle. Moments later the overheat alarm sounded and I shut it down. We were towed in.
- Tear down revealed damage to the #3 and #4 rings and pistons.
- I did not resume the repair until a few weeks ago.
- As the #1 piston was replaced two years ago, I went ahead and replaced all four of the remaining pistons with Wiseco.
- I did not see any specific root cause that started the damage. As the #3 piston has its own carb, and #4 and #5 feed from the same carb, I was doubtful that the problem was caused by a lean carb situation.
- With the engine reassembled, I put it on a set of water muffs and started it up. I let it run for 15-20 seconds before shutting it down due to no water coming from the telltale on the thermostat housing.
- I replaced the water impeller with a new one. The old one was less than two seasons old and did not appear to be damaged.
- I ran the engine on water muffs again and saw only one small trickle of water from the telltale. I shut it down after about 15 seconds.
- I removed the thermostat and confirmed that the passage to the telltale was open. There was some small debris in the thermostat consisting of a small piece of plastic and a leaf. I replaced the thermostat housing without the thermostat and ran the engine on muffs again. Again there was no flow from the telltale so I shut it down.
