Re: Need Help e90Tlcro - Broken down Moored out at sea.
Terminal A is questionable....is it the battery connection or the lead to the starter?
Terminal D is also questionable...is it the battery connection or the lead to the starter?
Terminal B is the starter solenoid pick wire that is normally colored yellow/red.
Terminal C is ground (appears to be).
If using the pliers, terminal A to terminal D if jumping with heavy pliers or equivalent.
If using the second method, jump terminal B to terminal A. If no response, jump terminal B to terminal D. One of these "jumps" will work, the other will do nothing.
Very hard to tell you without being there. That guy's hand is in the way....
But if you leave terminal C alone, you won't hurt anything.
