Onequickwrench
Thread starter- Joined
- Jul 16, 2021
- 4
Hello all.
First time Mercury owner here.
recently purchased a 1999 Key West center console with a tired 1999 carbureted 2.0 135Hp motor.
a budy had a functional 1998 Optimax 150 off his 1998 Grady White left over from a recent repower.
I hung the 150 on the transom, hooked up the fuel line, oil lines, battery cables, and control cables inside of an hour. Checked the remote “whip” between the two boats - they were identical, so I attached the whip to the motor harness and hit the starter switch.
low and behold the engine started right up, but immediately started a consistent beep whenever the motor is running.
oil tank and oil pump are primed, even went through the priming procedure to insure the oil pump is working.
engine won’t rev past 3000 rpm, but will idle with no issues.
good water flow from “pisser” and cylinder doesn’t get that hot after running, so it’s not overheating.
Anyone have any ideas? I’d really like to make it out to the lake this weekend
