Re: need help finding steering connection
TD's idea works well. I did the same thing for a dual engine installation - I made a pair of connectors out of angle. In order to make the horizontal tab longer on mine, I welded a piece of flat bar onto each and shaped them as needed.
One thing that I did find, though, is that they rusted quickly, even when painted. If I had to do it over again, I would have found some galvanized angle/flat bar and then would have used "cold galvanize" (spray can) on the areas that had been welded and/or cut.
One suggestion - if you use galvanized metal and do any welding on it, wear a good quality respirator. Also wear a leather apron. The zinc in the galvanized coating "pops" when you weld it and gives off a toxic cloud of fumes.
