Im having a hard time getting this thing going. good comp, good spark, fuel??, timing?? when you turn on key i have power to primer solenoid... shouldn't it only be hot when you push key in? it acts like it wants to go but it wont run. thanks!
Its starting to give me small backfires..???
There are 3 hoses, 2 small and one bigger. Did you take off the bigger one, fuel should come out, but not in the smaller ones.I took off the top hose and primed the bulb and fuel came out before I turned the key. Does this mean the solenoid is bad? It doesn't make any noise when key on, off, or pressed in. I took the box apart and pulled out switch. Doesn't appear to be tampered with... all wires intact... ??
Are u getting loud "pop!" sounds out the exhaust? Or just lean 'sneezes'. Or is it actually backfiring thru the carbs?
