duhmey
- Joined
- Sep 18, 2011
- 69
Gentlepeople,
I am removing the motor and lower unit from my Glastron V164 to provide access to the floor and bulkhead areas so that I can make repairs to the rotten wood that is there.
It comes equipped with a Volvo-Penta AQ130C motor and a Volvo-Penta AQ170 lower unit.
I am having a tough time getting the engine to separate from the lower unit. Per ?the book? I am to remove all the hoses and linkages that connect the engine and lower unit and then the bolts securing the lower unit to the transom and remove it that way.
The problem I am having is that the motor (as installed) is not bolted down and moves all over the place. I have decided (and verified with a boat mechanic here in town who ?sort-of? remembers how he has done it in the past) that I will re-attach the lower unit to the transom and pull the motor forward instead of fighting the two moving parts.
My question for you all is this, do I have to remove the upper gear housing in order to pull the drive shaft for this to work and 2) once all bonds between the engine and lower unit are separated what is the best method to separate the two parts?
Here is a pic of how she sits at the moment
