Need help identifying fuel line sizes - 1985 25hp Johnson J25RLCOS - pictures inside
SweetD
I'm looking to replace the fuel system lines in this motor I am refurb'ing, and cannot find the fuel line sizes in the picture below with an on-line search.
Can someone please let me know the fuel line (ID) diameter sizes in the attached picture - circled and labeled in red #1 and #2? These lines are to/from the manual priming assembly and the carb.
Also, the previous owner used zip ties for all the connections - I assume I should go with OEM fuel clips or something similar, any advice there?
Thanks! Dave
SweetD
Ok I figured out the larger of the two hoses in the pic is 5/32" - just need to know the smaller ones that are connected to the "T" fitting "#2"...no markings at all on those...so the hose to the fuel pump from the fuel pin inlet is 5/16", the mid-sized hose is 5/32", and the smallest size is "?"...
Thanks, Dave
