Need help identifying if exhaust elbow is good
Nicyutrick
Replacing the gaskets on the elbow exhausts cause it was rusting and leaking. Can I get a verification from the pictures that the elbow exhaust assembly is still good?
Thanks I’m advance!
Looks are ok, but are they flat?
Take a framing square or other steel ruler and suck and see if they are flat. Might need to put a flat file across them to true them up
Nicyutrick
Right on. Thank you. Didn’t know if cause they were leaking the rust in the ports was okay or not.
04fxdwgi25
Those rusty cavity areas are the water jacket. They will rust.....
tank1949
Thanks I’m advance!
If they are salt used and over 4 years old, pitch them. If not, you should create a piece of flat metal and block off motor side, then pour acetone into the water side and check for leaks.
