96RinkerCaptiva212
Thread starter- Joined
- Jun 4, 2017
- 84
Hello all, I'm currently wrapping up the install of my reman 5.7 Vortec. Need help identifying my ignition system so I can set timing. Pic below.
Background: After 4 trips on the water this season, I had water in the oil and 4 detonated pistons. Water in gas or my thermostat closed last fall when I was bringing antifreeze in with the muffs. Anyway, almost water ready again! Boat is a 96 Rinker 212. Had a non-vortec 5.7 in it and Alpha One (not sure what Gen). I just upgraded to Vortec with hi rise intake and 4 barrel holley. Yesterday, I set the idle timing at 6-8 degrees BTDC. Timing light seems to jump a little back and forth. I then read that if it is Thunderbolt V, I need to put the system in Base Timing Mode. So, I need to figure that out before I go any further. This number 807264-2 doesn't really come up with anything other than people selling their used one but not identifying.
In 96, it seems they crossed into the Thunderbolt V. I do not have a control module on the exhaust anywhere. I don't have a knock sensor. I just have this ICM which is mounted on the rear of the disty. I understand not all V's had knock sensors like I originally thought so now I'm confused. Is there any other means of identifying?
