Need help identifying my prop
raven1978
My setup is a VP AQ125A with 270 O/D. I need o know what prop I have on my drive and the only numbers stamped on the hub are 3669651160. This number doesn't match up to anything on the VP parts list. Any idea what size it is or another way i could find out what it is?
steelespike
Re: Need help identifying my prop
Did you look under the prop nut? A prop shop can measure it for you.
I find VP numbers very hard to follow. If you can help us with the details of your outfit.
year,hp,diesel, type and size of boat wot rpm and speed.We might be able get an idea where we are going.
raven1978
yes i have looked in the front and rear of the hub. Motor is a 1984 vp aq125a gas engine on a 21' bayliner ciera sunbridge. Cruise 25 mph @ 4400 rpm, wot 32 mph @ 5000 rpm. Numbers listed were stamped on the outside of the hub as there were no visible numbers on inside.
