I have just acquired two Scotty 1091 downriggers and, of course, would like to mount them on my boat. My boat is a 1987 Beachcraft 215c. If I remember correctly, Beachcraft was owned by Reinell at the time so the names are interchangeable. Anyway, the gunwales on the boat are pretty narrow as you can see in the pictures.
I have thought about replacing the wooden step with a wider one, but there are problems with that. The current step is just under 3" wide, and the mounting bases for the downriggers is 5 5/8" square. So the problems are 1) If the extra width is outboard I cannot put up any canvas in that area, and the gunwale probably could not handle the torquing forces from the downrigger either. 2) If the extra width is added INboard, then the seat gets pretty crowded, and I still have the torque problem. 3) If I split the difference then I have all of the problems.
I am thinking about something like in the last picture with the replacement step attached to a vertical board which is then attached to both the gunwale and the interior sidewall. This will help with the torque somewhat, but the sidewall is only 3/8" plywood so it probably won't help a whole lot. It does, though, seem like my "least bad" option.
I really don't have any other alternative locations that I can think of. This may be the strongest place I have to mount anything. The way the top of the transom is designed leaves me no place at all to mount anything. So if anyone has a similar mounting dilemma, and could post some pictures of your resolution, I would really appreciate it.
Any and all suggestions welcome.
Thanks,
Wayne
Thanks,
Wayne
