need help please, spirit outboard
ericman81601
hello to all, I have recently aquired an older motor that turns over if jumped direct to starter terminals but will not run. has good compression
The issue is I need to identify and get rewire/repair info to work on this
The cowling is black. Name on it is Spirit 50.
Sticker on the transom mount indicates that this is (or was) part of suzuki
here are the numbers, main data plate has 2 number spots, first one is
( 5001 ) second one is (d 11730 ) there is also a second plate with nothing except the number ( 500813 )
The wiring harness has been through hell, i can count over 50 splices and most join different colors, one wire may go 4 or 5 colors end to end.
any help is appreciated
Thanks
Eric
