Need Help Please!!
Dotong
Hi,
Can anyone tell me why my mercury 650 blueband cut out while running and now there is no spark? Any ideas for what to look for would be great!
Thanks
verado7
Re: Need Help Please!!
not without testing but surely it will be either stator ,trigger , switchbox , ignition ground , rectifier .
most common sudden no spark problems are switchbox failures .
you need a multimeter with dva adapter - iboats sells both so does CDI electronics.
dont just throw on a new part without doing a thorough test because a failing stator will knock out a switchbox at least every season or more - so will voltage on the ground line going to the switchbox .
if your willing to get the tools - post back .
