Re: Need help re-wiring my trailer!
Ok so I was able to go out and re-wire the trailer today. I went to Tractor Supply Co. and bought a submersible trailer light kit and harness adaptor. It came with everything minus the running lights. (which I have)
So I finally get the old wires and lights out and off and the new on. The regular lights and turn signals work. However, when I hit the brakes, all the lights go out!?!?! There are 3 ground wires. 1 from each light housing (left and right) and 1 at the front of the trailer where the connector is. The ground wires for the light housing, I connected them on the bolt that mounted the light but on the opposite side of the frame that it mounts to. (if that makes sense)(that should be a good ground right)
the 1 ground wire up front, I need to drill a hole in the trailer to be able to connect that properly but for the test I wrapped the wire around a part of the trailer frame so all 3 should be properly grounded.
Also, when the lights are on, I can't tell if they are really bright or normal. Almost as if it was the break lights when it was supposed to be the normal lights, then when I actually hit the breaks, all the lights go out. I may be wrong on this as both lights do it so I have nothing to compare the brightness to. They may just be bright lights.
