Need help removing 1987 powerhead of 20 hp remote control Johnson!
Mavenite
Trying to change the upper water tube grommet which requires removing the powerhead to get to it. Removed the 4 bolts under the lower engine cover and the 2 nuts above the engine cover under the powerhead. I also disconnected/removed everything else that I thought is needed to remove the powerhead. I pull it up and it moves about a half inch before it hangs on something that seems to be solid. I think it is the lever/shaft assembly ) for the remote control shift control) that connects to the top of the shift rod. But I cannot find how to disconnect it. If you think that is my problem, please tell me how disconnect. If not, and you think you know something else that is keeping me from lifting the powerhead up, please let me know!
Mavenite
