Need help removing mc-1 drive
Hodag1961
I have the shifter in forward. Removed trim bars and 6 nuts and washers. Can only get 1/2" gap and no further. Some blogs talk about a 7th screw under trim anode?? Any help is appreciated. Thanx in advance
Bt Doctur
that only applies if taking the unit apart, not for removal.
2 things, very bad alignment or a rusted gimbal bearing
DO NOT PRY ANYWHERE WITH ANYTHING
reattach the cylinders, cut 4 or 5 pieces of 2 x 4 3,4,5,6 inches long
place wood between the top of the housing and transom
CAREFULLY hit the trailer button to force the drive back, increaasing the length of wood as necessary
Hodag1961
Thanx. I did see a guy doing that in a video. This boat has been sitting a long time I should of mentioned.
