Minnesota Jeff
- Joined
- Apr 30, 2007
- 3
I have a 1989 4.3 OMC that I need to replace the exhaust flappers on. What I can't figure out is how to get to them! I remove the bolts holding the exhaust manifold to the head, and loosen all the clamps holding the rubber/exhaust parts together, but all I can do then is slightly rotate the manifold. I can't turn it enough to get it off the studs so i can lift the assembly up, and i can't get the clamped rubber parts to slide up or down enough to disassemble. the only option i see if to try and remove the 4 studs from the head so i can lift straight up... any ideas or tips that i need to know? I've heard this was a pretty simple job..... and it seems that it would be if I could just get to them!
