<< Need help restoring my father's 1986 Four Winns Horizon 190 Cuddy >>
Skipper Sean
Chadbud
I&#146;m not a Boat expert actually I&#146;m a newbie to big boats but the trim pump motor may not be bad. I would bet if you took the pump motor apart and cleaned the armature where it meets the brushes it will work again. My friend had troubles with his I took it off and tore it down and there was just some Iight corrosion on his armature I cleaned it up reassembled it and she works like a champ. If that don&#146;t work try replacing the brushes you can usually pick them up from a good auto electric repair shop. If you have any questions let me know I would be glad to help you out. I have been an automotive restoration tech for 35 years. An electric motor is an electric motor. And usually corrosion is the culprit..
jamieschillin
Im gonna follow along on this one as well...I have the same boat!!! Good Luck being a 1%er...
PCUK
You Tube is your friend when you need to know how to do something. It is the "University of the Practical Man".
kcassells
Chad you still working on the boat? Haven't eard from ya in a whiles.
