Mi_fiveo
Thread starter- Joined
- Jul 22, 2018
- 115
Per my other posts I’m trying to get the Evinrude 9.9 running. When I test for spark it is very intermittent with the key turned and seems to spark right as I let off of the key. I tested voltage at the key and found 12.7. It dropped to 10ish when the key was turned to start. If I unplug the red harness, I can pull start it but it idles pretty rough. If I try to plug the red plug back together, it dies immediately. Thinking someone must of wired the switch wrong or the wires in the harness are grounding out. I did try to cut the yellow/black kill switch wire and that had no effect. The kill switch was already removed when I bought it. Anyone have any ideas??? I’d appreciate the help.
