Need help to id the motor
andreipou
Just want to give an update.
Sometimes things are better than they look....
Good things: 110/115 psi compression and nice blue sparks when pulled after applying some fogging oil to cylinders.
Bad things: everything else was seized.
So, I disassembled cleaned and greased all moving parts.
Rebuilt carb and fuel pump.
New spark plugs.
The bolts on thermostat broke so, drilled out and re-threaded.
Replaced completely trashed thermostat.
New water pump kit.
Flashed all salt from cooling system.
With $100 and some time invested "ugly boy" starts with first pull and runs fine.
The only thing I do not like is that steering handle was removed to convert to RC.
Nordin
Nice to see you saved an old OB from recycling.
Maintain it well and it will last for a very long time.
Crosbyman
with the right mdl # you could try some salvage sites or put up a wanted ad on AOMCI site in Classifieds
try e-bay ... somebody has a corpse
airshot
Consider yourself very lucky....from the pics, I would have guessed it wasn't even a good parts motor !! Congrats on your determination to get her going !!
Crosbyman
I am always amazed at folks giving so little TLC to they investments
glad you got it going... a coat of paint and it will look like new... outside :)
