ok my trusty rude has finnally let me down
on the lake sunday start motor went to my fishing spot no problem
after about an hour tried to move this when the trouble began
started sounded a little rough didnt think much of it put in gear and stalled after about ten restarts it finnally kicked in and i motored closer to the ramp
ok then i started the kicker and let that run for about ten minutes and decided to try the 70hp again
same result after changing tanks from my 70hp tank to my kicker tank same dam thing
i had my buddy pump the ball while it was stalling and she caught and away we went back to the ramp no problems
at the ramp i shut it of and let it sit for about 5 mins and well same thing as before will not go into gear without stalling
so today i changed out the vro cause i have a spare
rebuilt all 3 carbs complete kits
checked compression 130 on all three
checked all ingition components with my meter all checked good resistance
power pack is one year old
coils and plus wires are one year old
timer base and stator look to be original
dont have a dva
now i put it in a barrel and it will idle but when i put in gear after its warmed up it will just stall
tach says it idleing at 1000
in gear before it stalls around 800
what gives i really dont know what eles to try hope some one has some other ideas
thanks
Bob
dont have a dva
thanks
Bob
