navigator175
- Joined
- Jan 14, 2010
- 7
I am in the middle of taking out VRO and going to pre-mix. The no-oil alarm was going off everytime I would go about 300 yds. at cruising speed. the engines is still creating white smoke, and all seems fine, but I am going to disconnect regardless. Anyways, I Pulled oil resevoir out. plugged the Oil line to engine, and disconnected the 2 wire application to block. My next step is to add oil to gas, then disconnect gas line into carbs and pump fuel line to till I see pre-mix.
My question is: did I remove alarm system by disconnecting wire, and am I missing any steps in the process?
Guidance would be greatly appreciated..
Cameron.
Cameron.
