I just purchased a 86 115 inline 6 jet that has been sitting in a shop for the last 2 years. The seller said that he took it to Tom's outboard and was told it needed a new stator. When I went to look at the motor I tried to hook it up to a battery to run a compression test but noticed that the fly wheel bolts were loose. After further inspection I found that the fly wheel was taken off and the stator bolts were loose. Looks like he tried to work on it. Anyway we bolted things down and tried to turn it over by hooking it to a battery and all we got was the starter solenoid click. So we had to perform a compression test by manually turning the fly wheel. Couldn't get much rotation but on all cylinders it was registering around 50 psi. I was wondering where should I start in getting this going. Can you get reliable compression numbers by manually turning the fly wheel or do you need to get the starter to turn the crank and get 3 to 4 compressions per cylinder? I've got a manual coming and am currently cleaning out the spider webs and dust. Thanks in advance.
