Re: Need help with 1979 mercury 900 90hp
Go forward and shift yer corntrol into neutral.
Then watch which cable moves as you put the corntrol into forward, (remember which one moves).
Once the corntrol is in forward and you push the corntrol handle all the way down the other cable, (throttle) will move, (make mental note of which is which).
The shift cable is attached to the hold down in the rail at the base of the powerhead and the throttle is attached to the pivot arm directly above it.
Hope that helps. JR
